#5371
Resin 3D printers using the SLA or DLP technologies are based on the photopolymerization process: the resin contained in the 3D printer tank is cured (hardened) by a light source (laser or projector) to form the object, layer by layer. Resin 3D printers use liquid resin as the 3D printing material, versus plastic filament for extrusion 3D printers. Resins used as printing material in SLA or DLP 3D printers are light-sensitive photopolymers (photo resins) which solidify when exposed to specific light beams. 3d printing services Jammu and Kashmir, Himachal Pradesh, Punjab,Uttarakhand , Uttar Pradesh and Haryana,chandigarth,kochi,bhopal,visakhapatnam india
What is SLA and how does it work?
Stereolithography, know as SLA, is an additive manufacturing process used by SLA 3D printers. A UV (ultraviolet) light is projected via a laser beam to solidify a liquid resin contained in a tank and form the object layer by layer. In a SLA 3D printer, the resin tank (also called vat) is filled with a photo-curable liquid resin (photopolymer resin). The UV laser beam traces the shape of the 3D design in the resin tank and solidifies the curable resin to form the final object, point by point (high accuracy), and layer by layer.
3D Printer Resins for SLA/DLP technology
SLA High Detail Resin
Castable Resin
flexible sla resin - HD Elastic
durable tough resin - HD strong
Snow White Resin - HD white
SLA Detail Resin can be well post-processed after printing. Our finishing options include
Removal of support structures (standard)
Sanding support structure scars (standard)
Clear coat coating (standard, UV protection)
Glas bead blasting (on request, free of charge)
France and Belgium have become the first-ever join[…]
MANCHESTER, England -- Mikel Arteta says Mancheste[…]
Petr Cech has said he is playing for his future at[…]
Two Chelsea fans were injured ahead of the Europa […]
