#5499
Achieving the highest quality standards is crucial in the aviation industry, where even the smallest of defects can have serious consequences. Besides the expansion of e-mobility, one of the most important recent developments in this field is the ability to produce components using additive manufacturing.
This is particularly beneficial in the aviation sector, where every single gram of weight saved can reduce flight operating costs. This is why toolcraft not only produces aircraft parts conventionally using CNC machining, but employs additive manufacturing processes as well. The company covers the complete process chain, from design and manufacture to quality assurance and testing. 3D metal printing has been an established manufacturing technique in its own right for many years, having successfully made the transition from being used for prototype production. Nadcap certification of the process is a further milestone in its development.
High standards in the aerospace industry
Even policymakers agree that the aerospace industry has a strategic role to play. In fact, hardly any other market is so pioneering when it comes to the use of innovative materials and processes. This is why R&D expenditure in this field, which is already double that found in other industries, is set to continue increasing for years to come. “Completely reproducible processes with full traceability are essential wherever people’s lives depend on the operational safety of end products,” explains Christoph Hauck, who is a managing director of toolcraft and is responsible for 3D metal printing. “To ensure that these requirements are met, suppliers are subject to strict quality standards.” Nadcap certification was launched in 1990 to avoid the costly and time-consuming need for individual assessments, which often actually resulted in the same inspections being performed twice. Developed by major aerospace companies, the programme defines a common standard.
Establishment of a common standard
The Performance Review Institute (PRI) has been responsible for administering the certification process from the outset. The universally accepted certification confirms that a company fulfils strict aerospace industry standards. The pooling of expert knowledge means that the programme provides an audit that is far superior to any individual inspection. It therefore improves supply chain quality, while simultaneously making processes more efficient for clients and suppliers. The Nadcap Management Council consists of senior quality leaders and managers from the key contractors and suppliers in the aerospace industry.
Attention is also given to the individual process steps. The manufacturing process is also inspected in terms of the method taken when changing the powder and the procedure followed in the event of system errors. From now on, this inspection will take place in line with Nadcap specifications at regular intervals, enabling the stringent standards to continue to be met in the future.
The engine is packed with innovations and one of them is 3D printed fuel nozzles. These parts are injecting a mix of air and kerosene into the combustion chamber: the core of the engine with a 1700°C (3000°F) temperature (to understand how an engine works, have a look at this video). No need to say that this is a very critical part. Each engine has 19 nozzles which means that CFM is going to produce 45,000 3D printed nozzles a year! 3D printing is definitely moving from the Rapid Prototyping denomination to Additive Manufacturing.
application of 3d printing in aerospace Andhra Pradesh|application of 3d printing in aerospace Karnataka|application of 3d printing in aerospace Kerala|3d printed airplane parts lucknow|additive manufacturing aerospace parts Tamil Nadu india|additive manufacturing aerospace parts Hyderabad|3d printing in aviation kanpur|3d printing in aviation Coimbatore |rapid prototyping bangalore| rapid prototyping Mumbai pune maharashtra| industrial 3d printing jamnagar| industrial 3d printing Ernakulam|
Additional certifications
toolcraft is also DIN 2303 certified. This certification is required by companies that use thermal joining processes (welding/brazing/thermal spraying) when manufacturing or repairing military products. DIN 2303 certification is required for components belonging to the classes BK1 to BK3, is granted differently depending on the component class and always takes the materials into consideration. toolcraft works continuously to improve its processes and its entire process chain, including the performance of optical and tactile measurements and non-destructive testing, which meets the requirements of Nadcap. The company also evaluates the dynamic strength of various metals using fatigue testing performed in its own lab.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | movers and packers rates in vadodara | packers and movers surat | car transport service india | transportation service india |best packers and movers in vadodara |Car Transportaion Service in vadodara Gujarat |Ware House Service in vadodara Gujarat |movers in vadodara |Local movers and packers in vadodara|packers and movers charges vadodara|packers and movers charges vadodara | packers and movers in baroda | agarwal packers and movers ahmedabad| packers and movers ahmedabad satellite |packers and movers ahmedabad charges| local packers and movers in ahmedabad || Packers and movers india | packers and movers vadodara| packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara | packers and movers surat |best Packers and movers india | packers and movers Ahmedabad |packers movers vadodara |movers and packers rates in vadodara |packers and movers charges vadodara |best packers and movers in vadodara |movers in vadodara || Packers and movers vadodara | Movers and Packers in vadodara | Packers and Movers in vadodara | packers and movers services vadodara gujarat india |
#8051
