Pagina 1 di 1
Top New 3D Printing Materials You Should Try
MessaggioInviato:ven feb 02, 2018 8:36 am
da vexmasales
Indeed, for most 3D printer users, having the freedom and flexibility to choose from a wide range of 3D printing materials that satisfy all kinds of production demands is crucial. At 3D Platform, we strive to provide customers with a truly open source, large format 3D printing platform which welcomes both open source materials and open source software. The 3D1000 large format 3D printer allows customers to step into large format 3D printing with low startup cost, minimal maintenance cost, and economical material costs. Every month, there are many new and exciting 3D printing materials being introduced to the market. 3d Printing Fused deposition modeling in mumbai pune delhi telangana Chhattisgarh india
On the desktop it is mainly PLA followed by ABS. Nylon. Other materials such as Colorfabs Bronzefill are becoming popular. 3d printing materials used
Stereolithography (SLA) resins are popular in prototyping and mold making. These photopolymers are also used for Objet, Envisiontec and Formlabs systems.
In terms of raw materials that are put into the printing system to create the 3-D objects, there seem to be relatively few limitations on what can be used.
Currently, plastics are the most widely used materials in additive manufacturing, and the important ones are listed below: 3d printing in mumbai pune maharashtra india
FDM Materials
taulman alloy 910 nylon
ABS - acrylonitile butadiene styrene or 'lego' plastic – a very common choice for 3D printing
3d printing pla - polylactic acid – Is available in soft and hard grades, is becoming very popular and may overtake ABS in the near future
3d printing with pva - polyvinyl alcohol – This is used as a dissolvable support material or for special applications.
printing on polycarbonate (PC) – Polycarbonate requires high-temperature nozzle design and is in the proof-of-concept stage.
SOFT PLA - polylactic acid – Is rubbery and flexible, available in limited colors and sources. As 3D printing spreads, may get easy to find.
you can 3D print with HIPS (High Impact Polystyrene) on a FDM machine. Results can be good if you have the right HDPE
new arrivals another materials
TitanX : ade, high-performance and FFF/FDM-optimized ABS based engineering filament. TitanX is the evolution of ABS into a warp-free filament with unsurpassed mechanical properties and is extremely suitable for 3D printing large scale and high precision engineering objects.
ApolloX Material : ApolloX is a professional high-performance engineering filament, which is based on an uniquely industrial-grade modified ASA (Acrylonitrile Styrene Acrylate) compound.
PC - Plus : Parts made with Polymaker PC show significantly improved mechanical strength compared to ABS and PLA under almost any deformation mode. Polymaker PC Plus shows good optical clarity, rendering parts with an attractive crystal shine!Polymaker PC offers outstanding fracture toughness that is simply unobtainable from other 3D printing materials of similar stiffness.
PCTPE : PCTPE stands for "Plasticized Copolyamide TPE" or a substance co-polymer of very adaptable nylon and TPE (thermoplastic elastomer) . PCTPE has several unique features that allow any user to print a highly flexible part with the added durability of our nylon polymers.
