#5486
Introduction
The Aerospace and Defense (A&D) industry is a great example of utilization Additive Manufacturing (AM) (commonly referred to as 3D printing) with a clear value proposition and the ability to create parts that are stronger and lighter than parts made using traditional manufacturing.
The A&D industry was a very early adopter of 3D printing and still continues to contribute heavily to its development. Some aerospace companies began using this technology as early as 1989 and over the next couple of decades, adoption of 3D printing increased substantially. In 2015, the Aerospace & Defense industries contributed approximately 16% of 3D Printing’s $4.9+ billion global revenues.
This article presents an overview of the use of 3D printing in the aerospace industry. It will discuss design requirements for parts used in airplanes and give design recommendations for common (and not-so-common) aerospace applications. A range of popular 3D printing materials are suitable for the aerospace industry and are presented along with case studies, where 3D printing has been successfully implemented.
Integrating 3D Printing in the Design Workflow
3D printing is implemented at all stages of the design workflow for applications in the aerospace industry. Here is how:
Design communication
Designs in the aerospace industry often begin as concept models showcasing a component of an aircraft. These are often also regularly used for aerodynamic testing, which is of critical importance for aerospace. SLA and Material Jetting are used to produce high detail, smooth, scale models of aerospace designs. Accurate models allow design intention to be clearly communicated and showcase the overall form of a concept.
Validation stage
Prototyping using 3D printing is now commonplace in the aerospace industry. From a full-size landing gear enclosure printed rapidly with low-cost FDM, to a high-detail, full-color control board concept model, there is a 3D printing process suited to every prototyping need. Engineering materials for 3D printing also allow for full testing and validation of prototype performance.
Pre-production
One of the areas 3D printing has been most disruptive and valuable is the production of low-cost rapid tooling for injection molding, thermoforming and jigs and fixtures. Within the aerospace industry, this allows for tooling to be quickly manufactured at a low cost and then used to produce low to medium runs of parts. This validation mitigates the risk when investing in high-cost tooling at the production stage and can also provide production components for quantities up to 5,000 to 10,000 parts.
Production
Because production volumes in the aerospace industry are generally large (more than 70,000 parts per year) 3D printing has predominantly been used in the past as a prototyping solution rather than the manufacturing of end parts. Improvements in the size of industrial printers, the speed they are able to print at and the materials that are available mean that 3D printing is now a viable option for many medium-sized production runs, particularly for high-end interior build-outs.
Customization
3D printing technologies have a significant impact on the aerospace industry when the cost of highly complex one-off components can be justified by a substantial improvement in aircraft performance: the average corporate aircraft travels 75,000 miles per month and a single component that was designed and manufactured with 3D printing reduces air drag by 2.1%, reducing fuel costs by 5.41%! Small adjustments like this example affect life in a huge way.
Parts can be tailored to a specific aircraft (custom, lightweight bracketry) or type of aircraft (cargo, passenger or even helicopter). 3D printing also provides part consolidation and topology optimization of many custom aerospace components. This is further highlighted in the case study in a latter section.
Common 3D printing use-cases in aerospace
Jigs & Fixtures
Big benefits exist for some of the more mundane 3D printing applications, including jigs and fixtures making. For each individual aircraft, companies have hundreds of fixtures, guides, templates, and gauges 3D printed, generally with 60 to 90 percent reductions in cost and lead time compared to other manufacturing processes.
Surrogates
Surrogates are placeholder parts used throughout production that represent components that are later installed in final assemblies. Surrogates are mainly used for training. NASA and several air force bases commonly use surrogate parts on the production floor.
Mounting brackets
3D printing is commonly used to manufacture structural, low-volume metal brackets (with DMSL/SLM) that mount complex life saving systems to the interior wall of a plane.
High detail visual prototypes
3D printing with Material Jetting is able to produce multicolor designs with a surface finish comparable to injection molding. These visually appealing models allow designers to get a greater understanding of the form and fit of a part before production decisions.
This highly accurate method of prototyping is also ideal for aerodynamic testing and analysis, as the surface finish that is able to be achieved is often representative of a final part.
3D printing is used routinely to manufacture aerospace components that rely on aesthetics over function, such as door handles and light housings to control wheels and full interior dashboard designs.
Manufacturing Considerations
Geometric design freedom
Aerospace applications make use of advanced engineering materials and complex geometries in an attempt to reduce weight while improving performance. Aerospace parts frequently include internal channels for conformal cooling, internal features, thin walls and complex curved surfaces.
3D printing is capable of manufacturing such feature and moreover it allows the fabrication of highly complex and lightweight structures with high stability. This high degree of design freedom enables the topological optimization of the parts and the integration of functional features in a single component. Also, certain 3D printing technologies, such SLA, DMSL/SLM, FDM and Binder Jetting, are capable of small batch production at reasonable unit costs.
Consolidating assemblies into a single part
The design freedom offered by 3D printing process also allows the consolidation of multiple parts into a single component. This leads to weight savings (and thus cost reduction) and also reduces the amount of inventory kept at any time.
urrently satellites include geometrically specific brackets that link the body of the satellite with reflectors and feeder facilities mounted at each end. Engineers at Airbus in its Defense and Space division faced two key challenges regarding the construction of the brackets:
Primarily, the brackets must affix the component securely to the satellite’s body. Secondly, the main function of the brackets is to mitigate the vast temperature fluctuations experienced outside of earth’s atmosphere.
The brackets are critical functioning as an insulating component: the temperature ranges from –170 to +100°C, hence, the stress on the part is extremely high. Very few materials are able to meet these requirements. However, as often the case in the aviation and aerospace industry, titanium turned out to be the engineer’s choice.
rapid prototyping bangalore| rapid prototyping Mumbai pune maharashtra| industrial 3d printing jamnagar| industrial 3d printing Ernakulam| industrial 3d printing Coimbatore| industrial 3d printing Dadra & Nagar Haveli| prototype manufacturing companies in jamsedhpur india| prototype manufacturing companies in secundrabad india| prototype manufacturing companies in satara india| additive manufacturing applications nagpur| rapid manufacturing Kharagpur| rapid manufacturing Dehradun
The end result ended up covering the entire spectrum of the advantages of 3D printing as an alternative to traditional manufacturing:
Utilized premium material with little waste = cost savings
Part consolidation = fewer man hours required for assembly
Optimised geometry = higher performance designs not subject to traditional constraints
Lightweight components = fuel savings over the life of the project
From technical advantages to targeted cost reductions, many milestones were achieved: savings purely in production were more than 20%. Additionally, the engineers successfully decreased part mass: the weight advantage is over 300 g, which means nearly one kilogram reduction per satellite.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara gujarat inadia | packers and movers surat | car transport service india | transportation service india |Relocation Service in Gujarat |Car Transportaion Service in vadodara Gujarat |Ware House Service in vadodara Gujarat |Office Shifting Service in vadodara gujarat Gujarat |Local Packers and Movers vadodara Service
local movers and packers in vadodara | packers and movers surat |Top best Packers and movers india | packers and movers in Baroda| packers and movers Ahmedabad | packers and movers in vapi | packers movers vadodara |packers and movers in surat | packers and movers rajkot| packers and movers in rajkot|
#8207
Siti scommesse online
CD 25 Be Be To XX XV Ja Iv Fy XX Te L[…]
Va 25 Be Be Vi Gh Ro Ja Fr XI XX Te X[…]
CD 24 Be Be Hu Oc Vi XI Vi XX XX Al R[…]
Stampa collettiva.
MP 25 Be Be Mu El Vi XI Ri DV XX Te X[…]
