#5518
Manufacturing
According to Manufacturing Business Technology,3D printing in manufacturing is becoming more accessible and easier to use, despite some remaining limitations surrounding the speed and scale to which additive manufacturing can be used in the industry.
However, modern manufacturing facilities are adopting 3D printing, artificial intelligence, robotics and similar innovations to automate and improve the space. Where the real benefits come into play are the age-old processes that have long been stagnant in the industry.
3D printing, for instance, can help accelerate the speed and advancement of design, testing, prototyping and more. In prototyping, once an initial design or makeup has been decided, a physical mock-up can be printed in hours to minutes.
Not to mention, the cost of printing with this technology never changes. It's the same cost to print a component or item, whether you need one or 10,000.
But the most important element is that products, designs and items can be printed anywhere. Companies and organizations don't need to have a separate facility just for manufacturing these days, unless they're dealing with inventory in the thousands.
Designed to additively manufacture large-scale parts and prototypes from high-value metals like titanium, tantalum, Inconel, niobium, and other alloys, the EBAM300 is the only 3D printer on the market that has produced a metal structure exceeding 10 feet in length.
Beyond size, the EBAM 300 is also one of the fastest industrial 3D printers commercially available with a deposition rate ranging from 7 to 20 lbs. per hour. It produced a 10-foot-long titanium aircraft structure in 48 hours at a rate of approximately 15 lbs. of metal per hour. In general, forgings that used to take 6-12 months to complete can be completed in 2 days with the EBAM 300.
This Electron Beam Additive Manufacturing (EBAM) system also provides an extremely high degree of control over part geometry and material composition because of its patented IRISS Closed-Loop Control Technology. Savings on raw materials—often precious metals—can be huge with EBAM (up to 80% for large-scale parts) because of the substantial reduction of material waste.
The EBAM 300 is used to create, improve, and repair next-generation end-use technology in the aerospace and defense industry, energy industry, metals industry, and many other verticals. It is a full-scale means of production for corporations and institutions in need of a system that can do more than build flimsy prototypes and/or headline-grabbing objects without real function.
This marks a sharp contrast between Sciaky and other 3D printing companies that say they sell “the largest 3D printer in the world” because it’s a marketable proposition.
The truth is: while there are indeed 3D printing systems that can print entire buildings, houses, car replicas, bikes, statues, etc., generally, the bigger the printer, the weaker the business case.
rapid prototyping bangalore| rapid prototyping Mumbai pune maharashtra| industrial 3d printing jamnagar| industrial 3d printing Ernakulam| industrial 3d printing Coimbatore| industrial 3d printing Dadra & Nagar Haveli| prototype manufacturing companies in jamsedhpur india| prototype manufacturing companies in secundrabad india| prototype manufacturing companies in satara india| additive manufacturing applications nagpur| rapid manufacturing Kharagpur| rapid manufacturing Dehradun
For example, if you run a Google search for “who makes the largest 3d printer?” you will find that most mega-scale 3D printers are a) not commercially available and b) are only useful to a small consortium of individuals and even fewer real-life applications. Why? In a nutshell, huge parts made out of sand, plastics, and other particle materials aren’t practical for most companies.
That’s not the case with Sciaky. We may not be able to say that we make the biggest 3d printer on the planet, but we do make the world’s largest 3d printer that is fit for the industrial/commercial production of functional metal parts.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | packers and movers in baroda | packers and movers surat | car transport service india | transportation service india |best packers and movers in vadodara |Car Transportaion Service in vadodara Gujarat |Ware House Service in vadodara Gujarat |movers in vadodara |Local movers and packers in vadodara|packers and movers charges vadodara|packers and movers charges vadodara | packers and movers in baroda | agarwal packers and movers ahmedabad| packers and movers ahmedabad satellite |packers and movers ahmedabad charges| local packers and movers in ahmedabad ||
Packers and movers india | packers and movers vadodara| packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara | packers and movers surat |best Packers and movers india | packers and movers Ahmedabad |packers movers vadodara |movers and packers rates in vadodara |packers and movers charges vadodara |best packers and movers in vadodara |movers in vadodara || Packers and movers vadodara | Movers and Packers in vadodara | Packers and Movers in vadodara | packers and movers services vadodara gujarat india |
#8216
