#5531
Get the next big thing to market faster with 3D printing
Timing can be as important as the idea itself. In the competitive consumer products field, in-house 3D printing enhances collaboration, shrinks time to market, and helps keep new devices under wraps until launch.
Industrial designers, mechanical engineers, packaging designers, graphic artists and marketing staff all use prototypes to understand a product’s aesthetic and functional appeal. 3D printing gives your idea the speed to match its brilliance.
3D printing offers an alternative solution to traditional design and manufacturing limitations. Simultaneously produce multiple design iterations so that each can be tested for form, fit, and function. At the same time, check ergonomics, and visual appeal, all without any expensive tooling. Accelerate your time to market while reducing costs by utilizing EnvisionTEC’s 3D printing technology to create the most complex geometries quickly and easily. Durable end-use parts are also possible with the additive manufacturing capabilities of 3D printing.
For astonishingly realistic appearance in a 3D printed model, Stratasys PolyJet 3D printers work with an impressive array of materials including clear, flexible and rigid. Design reviews and focus-group sessions can be more productive with lifelike prototypes.
For prototypes built from production-grade thermoplastics, Stratasys offers patented FDM Technology. FDM 3D printers work with ABS, PC and other thermoplastics, so you can build prototypes from the same material as the finished product. Get your concept off the starter’s block in record time.
Consumer ProductsConsumer Electronics
The triple requirements of attractive design, small form factor and high production efficiency make designing truly successful consumer electronics a real challenge. Stratasys PolyJet 3D printers produce models with exceptionally thin walls — 0.6mm or less — ideal for small devices densely packed with minute components.
Consumer ProductsSporting Goods
Sporting goods prototypes often require a combination of rigid and flexible materials integrated into one part — think of the various levels of flexibility in a shoe sole — and even a combination of opaque and transparent elements. PolyJet technology 3D printing can produce a part with a mixture of materials in one automated job, so it’s ideal for sporting goods designers.
3D printing in the consumer goods industry vapi gujarat| 3D printing in product design Mumbai pune maharashtra| 3D printing in product design Nashik| product design in gurgaon| 3D printing in product design Bhubaneswar| consumer goods supply chain in secundrabad| 3D printing in the consumer goods industry satara
FDM Technology’s production-grade thermoplastics have the impact strength and durability to withstand the stress of tough functional prototyping.
Consumer Products
Toys
When prototypes must evoke the look and feel of the finished product, PolyJet 3D printing technology offers a great opportunity. Finely detailed models with a mixture of rigid, flexible and clear materials can be built automatically.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | packers movers in vadodara | packers and movers surat | car transport service india | transportation service india |best packers and movers in vadodara |Car Transportaion Service in vadodara Gujarat |Ware House Service in vadodara Gujarat |movers in vadodara |Local movers and packers in vadodara|packers and movers charges vadodara|packers and movers charges vadodara | packers and movers in baroda | agarwal packers and movers ahmedabad| packers and movers ahmedabad satellite |packers and movers ahmedabad charges| local packers and movers in ahmedabad ||
Packers and movers india | packers and movers vadodara| packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara | packers and movers surat |best Packers and movers india | packers and movers Ahmedabad |packers movers vadodara |movers and packers rates in vadodara |packers and movers charges vadodara |best packers and movers in vadodara |movers in vadodara || Packers and movers vadodara |
#8217
NEW YORK -- As the Minnesota Timberwolves front of[…]
NEW YORK -- Some have wondered why the NBA didn't […]
The Chibuku Super Cup kicks off this weekend, with[…]
