#5476
Electronic circuits or components can be created with the assistance of a very special type of printer, where the substrate which is directed through the nozzles contains conductive ink. Being built up in minuscule lasers in the same way as other types of additive manufacturing, complex electronic parts can be created far more quickly.
There are now 3d printers which can not only print conductive ink, but also extrude polymers and other plastics, creating some of the first multi-material printers available on the market.
Why use Additive Printing?
There’s little point using new technology for the sake of it, and with efficient processes already in place for creating electronics, it’s worth considering whether additive manufacturing really offers anything different.
One of the most beneficial reasons to contemplate using additive manufacturing processes rather than conventional engineering is the ability to create electronic circuits in very small spaces.
Technology such as mobile phones has become microscopic in recent years and being able to print directly onto 3D surfaces has made this possible. Rather than having to include separate circuit boards, wiring and cabling, the assembly process is vastly reduced and the overall weight lowered too.
It’s not just consumer products where additive printing of electronics can be used; it’s also present in a number of different industries. Additive manufacturing machines can produce conductor, resistor, dielectric and semiconductor inks which can be processed to create both active and inert components.
Shielding, antennas and sensors are just some of the types of electronic components which can be created.
Combining additive manufacturing in both the aerospace and electronics industries provides some very advantageous technology, including the ability to print directly onto the wing of unmanned aerial vehicles, creating a lighter and more streamlined design. These aerodynamic qualities shouldn’t be underestimated either, as in the past protruding antenna could have a very detrimental effect on the overall design’s performance.
Additive manufacturing also requires less human input; this saves on money as only quick periodic checks are required to ensure all is on track. This means costly errors are also eliminated as a possibility.
And of course, being able to create a truly innovative product, and get it to market quickly carries its own advantages. Additive manufacturing is rapid and allows a fast turnover of a new concept, sidestepping the lengthy process than a more conventional design would take to produce.
Some benefits apply possibly more to electronics than to other areas, because of the relative ease in which electronic components can be printed. Because electronic parts can be constructed using a range of specialised inks, rather than industrial materials such as metal powders and binders, it’s far easier to have a printer for the purpose of 3D printing.
This means that there’s a far lesser need to buy and store parts in advance in anticipation of some possible future need. The ability to print out 3D electronic components as and when needed means resources can be far more flexibly used.
Being able to respond to demand rather than stockpile components is a far more economical way to work, but that’s not the only financial benefit. Compared to conventional engineering techniques, there’s far less wastage as any materials in the printer left unused can simply be utilised on the next project. Conventional manufacturing techniques can result in up to 90% wastage of materials.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | movers and packers rates in vadodara | packers and movers surat | car transport service india | transportation service india
Packers and movers india | packers and movers vadodara| packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara | packers and movers surat |Top best Packers and movers india | packers and movers in Baroda| packers and movers Ahmedabad | packers and movers in vapi | packers movers vadodara |packers and movers in surat | packers and movers rajkot| packers and movers in rajkot|
