Hai un'idea, un progetto? Mostralo alla comunità e chiedi consigli. Siamo qui pronti per aiutarti a realizzarlo!
#5503
Additive Manufacturing (3D Printing)
Additive Manufacturing can be defined as processes in which material is coagulated or bonded under the control of a computer to create a three-dimensional object with the material being added together. Objects used in the process can be of any shape and are produced using digital model data from a 3D model or another electronic data source such as Additive Manufacturing File (AMF) file. Additive manufacturing is employed to achieve mass-production.
In other words, additive manufacturing (3D Printing) can be defined as a process by which 3D design data is used to build up a component in layers by depositing material.
Industrial Additive Manufacturing
Industrial additive manufacturing, which is a game-changing production technology, is gaining momentum in the commercial manufacturing environments.
Additive manufacturing (AM) is commonly known as ‘3D Printing’, a production technology that is driving the next industrial revolution.
• 3D objects are built by adding layer by layer of material
• Objects can be made virtually of any shape using a digital model
Industrial Additive Manufacturing Vs 3D Printing
There is not much difference between Additive Manufacturing and 3D Printing. However, additive manufacturing and 3D Printing are synonyms for the process of building parts by joining material layer by layer using a CAD file.
People who work in an industrial or manufacturing industry refer the process as ‘Additive Manufacturing’ whereas media, other people refer it as 3D Printing.
Additive Manufacturing (3D Printing) Process
Additive Manufacturing (3D Printing) involves the process of building layers of a material to create a solid object using CAD, STL conversion and files manipulation, printing, removal of prints, and post-processing.
1. CAD
In the additive manufacturing process, producing a digital model is the initial step. To produce a digital model, the most common method is CAD (Computer Aided Design). There are several free and professional CAD programs that are compatible with the additive manufacturing. On the other hand, reverse engineering can also be used to generate a digital model via 3D scanning.
2. STL conversion and file manipulation
The second step included in the additive manufacturing process is converting a CAD model into an STL (Stereolithography) file. To describe the surfaces of an object, STL uses triangles (polygons). Before converting a model to an STL file, model limitations such as physical size, water tightness and polygon count should be considered.
After generating the STL file, it is imported into a slicer program. This program takes the STL file and converts it into G-code, which is a numerical control (NC) programming language. This language can be used in Computer-Aided Manufacturing (CAM) to control automated machine tools including 3D printers and CNC machines.
3. Printing
At this stage, the print material is loaded into the printer. To produce accurate points, maintenance of machine parts, calibration is important. The raw materials used in additive manufacturing have a limited shelf life and require careful handling.
Moreover, most additive manufacturing machines do not need to be monitored after the print has begun. An automated process will be followed and the issue/problem arose when the machine runs out of material or if there is a software problem.
4. Removal of prints
Remove of the print is simple as it requires the separation of a printed part from the build platform.
5. Post processing
Post-processing procedures vary by printer technology. For example, SLA (Stereolithography Apparatus) requires a component to treat under UV before handling; metal parts need to be stress relieved in an oven while FDM (Fused Deposition Modeling) parts can be handled right away.
In this step, 3D printing materials are capable to be sanded and other post-processing techniques including polishing, high-pressure air cleaning, tumbling, and coloring are implemented to prepare a print for end use.
Benefits of Additive Manufacturing (3D Printing)
Additive Manufacturing (3D Printing) allows for highly complex structures that can be extremely light and stable. It also enables a design-driven manufacturing process where design determines production.
It is used as it provides various advantages such as:
1) Additive manufacturing (3D Printing) saves money as you do not need mold tools for your prototype and expensive production.
2) It mitigates risks and you can easily alter or redesign an existing mold without expensive risks and processes.
3) 3D Printing offers clearer communication ensuring that no construction requirement is left to the imagination. It offers the exact representation of the desired product greatly minimizing errors with the finished product.
4) This is a great way of testing the market potential of your product before getting into the production with full force. It is also a simple way of making improvements to it before mass production.
5) Using 3D printer, you can customize and personalize product parts to fit the unique needs and this can be very important, especially for dental and medical industries or even the fashion and jewelry industries.
6) You can build things that seem impossible, such as square interior cavities, holes which change direction and overhangs. You can bring your geometry ideas into reality using a good 3D printer.
Applications of Additive Manufacturing (3D Printing)
Additive Manufacturing has several applications in a variety of industries.
• For example, within the medical industry, doctors can create models of the human body and organs for use in research and medical education.
• Within the architectural field, architects can create model scales of building to present to clients.
• Using this, auto parts can be created that might currently be made on assembly lines for the automotive industry and for manufacturing industrial equipment and consumer products.
Mass Customization
Companies often opt for mass production to gain economies of scale and keep the product cost low. Product customization is expensive and usually reserved for customers with an ability to pay a premium. The advent of 3D printing technology aims to remove this barrier with mass customization at a reasonable cost. For instance, 3D printers can be used to design a perfect replica of the actual knee and print it for use in knee replacement surgeries.
rapid prototyping bangalore| rapid prototyping Mumbai pune maharashtra| industrial 3d printing jamnagar| industrial 3d printing Ernakulam| industrial 3d printing Coimbatore| industrial 3d printing Dadra & Nagar Haveli| prototype manufacturing companies in jamsedhpur india| prototype manufacturing companies in secundrabad india| prototype manufacturing companies in satara india| additive manufacturing applications nagpur| rapid manufacturing Kharagpur| rapid manufacturing Dehradun
Low Volume Production
The concept of minimum order quantity (MOQ) arose due to minimum order stipulations placed by suppliers manufacturing in large volume. For instance, creating a mold might cost $10,000 with a $1 price for each incremental part, making the total price for the first part as $10,001. If the requirement is only for a few parts, then it wouldn’t make economic sense to manufacture it for such low volumes. Today, companies opt for 3D printing for manufacturing parts and products at low volume.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | movers and packers in vadodara | packers and movers surat | car transport service india | transportation service india |best packers and movers in vadodara |Car Transportaion Service in vadodara Gujarat |Ware House Service in vadodara Gujarat |movers in vadodara |Local movers and packers in vadodara|packers and movers charges vadodara|packers and movers charges vadodara | packers and movers in baroda | agarwal packers and movers ahmedabad| packers and movers ahmedabad satellite |packers and movers ahmedabad charges| local packers and movers in ahmedabad ||
Packers and movers india | packers and movers vadodara| packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara | packers and movers surat |best Packers and movers india | packers and movers Ahmedabad |packers movers vadodara |movers and packers rates in vadodara |packers and movers charges vadodara |best packers and movers in vadodara |movers in vadodara || Packers and movers vadodara | Movers and Packers in vadodara | Packers and Movers in vadodara | packers and movers services vadodara gujarat india |
#8608
