Hai un'idea, un progetto? Mostralo alla comunità e chiedi consigli. Siamo qui pronti per aiutarti a realizzarlo!
#5509
3D printing production is still in its infancy, but it is already inevitable. And if you look closely, you will find numerous indications that this historic shift is already well underway.
For the last decade, 3D printing has been the playground of the maker community, while commercial applications have been limited to prototyping. But now, industrial 3D printing has reached its tipping point, and is about to go mainstream in a way that will revolutionize the economy.
3D production of functional end-use parts is already one of the fastest growing areas in the manufacturing sector. In 2014, a PWC survey found that 11% of manufacturing companies had already switched to volume production of 3D printed parts or products. As costs continue to drop and quality rises, it will be impossible to put this genie back in the bottle.
Here are seven ways that 3D printing production is already in use today and disrupting business as we know it.
1. True Rapid Prototyping. 3D printing has been used for nearly 20 years to create physical replicas of new part or product designs. Often referred to as rapid prototyping, this process has typically been anything but rapid, with service providers often taking a week or more to deliver a single piece. But recent breakthroughs in automation coupled with the entry of global distribution companies like UPS have changed everything, in some cases leading to same-day production and shipping. These changes are dramatically collapsing design cycles. A product that would need a month to go through three or four design changes in the prototyping phase now takes a week. Products are getting to market faster, and companies are saving significant time and money.
2. Rapid Design Iteration (A/B testing of physical products). 3D printing has moved beyond prototyping into first-run production, allowing for true market testing and rapid design iteration. Witness Ford: For most of the company’s existence, engineers had to create a brand new mold if they wanted to test a prototype engine. The process would typically take six months and cost hundreds of thousands of dollars. Today, Ford is 3D-printing these molds in four days at a cost of $4,000. Taking advantage of this enormous reduction in time and cost, Ford recently decided to make not just a single engine prototype for a new car, but numerous versions to be tested simultaneously. No longer bound by the constraints of the old industrial process, engineers can explore dozens of variations and rigorously test them all, fine-tuning the engine’s performance.
rapid prototyping bangalore| rapid prototyping Mumbai pune maharashtra| industrial 3d printing jamnagar| industrial 3d printing Ernakulam| industrial 3d printing Coimbatore| industrial 3d printing Dadra & Nagar Haveli| prototype manufacturing companies in jamsedhpur india| prototype manufacturing companies in secundrabad india| prototype manufacturing companies in satara india| additive manufacturing applications nagpur| rapid manufacturing Kharagpur| rapid manufacturing Dehradun
The result of advances in 3D printing production will be an eventual blurring of the lines between prototype and product. Smaller companies will reap great benefit from this technology, introducing innovative products without huge inventory expense. Multiple versions of industrial parts or even consumer goods can be tested for use in the marketplace—the ultimate focus group. The sort of A/B testing that is constantly done in the digital world is now possible in the physical world.
3. Low volume production. With conventional manufacturing, a company has to commit to creating tooling or molds before a single end use part can be produced. If creating a mold costs $50,000 and each incremental part costs $.50, then the very first part will cost $50,000.50! This works out fine if you are producing millions of parts. But what if you only need 500? With 3D printing, there are no set-up costs whatsoever.
Packers and movers vadodara | packers and movers Ahmedabad | packers and movers in vapi | movers and packers rates in vadodara | packers and movers surat | car transport service india | transportation service india |home shifting services in vadodara |Domestic packing Services in vadodara Gujarat |international parcel Services in vadodara Gujarat |movers in vadodara |rail cargo transport in vadodara|top industrial transporter vadodara|packers and movers charges vadodara | packers and movers in baroda | agarwal packers and movers ahmedabad| packers and movers ahmedabad satellite |packers and movers ahmedabad charges| local packers and movers in ahmedabad ||
Packers and movers india | packers and movers vadodara| packers and movers Ahmedabad | packers and movers in vapi | local movers and packers in vadodara | packers and movers surat |best Packers and movers india | packers and movers Ahmedabad |packers movers vadodara |movers and packers rates in vadodara |packers and movers charges vadodara |best packers and movers in vadodara |movers in vadodara || Packers and movers vadodara | Movers and Packers in vadodara | Packers and Movers in vadodara | packers and movers services vadodara gujarat india |
#8609
Michael
Sensore temperatura CTC
Дарите подарки
